Creating a component in Proteus with spice file and it can be simulated
Antor
Member level 2
Member level 2
Hello there,
I have a spice file for a component and I need to create this component in ISIS and make it able to simulate.
Datasheet link
Here is the spice model for the component.
* HCPL-3140/HCPL-0314 SPICE Macromodel
* Rev. B
* 07/07
* ZFC
* This is the behavioural model for the above-mentioned part number.
* It is valid for functional simulation over the range specified below.
* Supply range: 10 to 30V
* Macromodels provided by Avago Technologies are not warranted
* as fully representing all of the specifications and operating
* characteristics of the product.
* Macromodels are useful for evaluating product performance but they
* cannot model exact device performance under all conditions, nor are
* they intended to replace breadboarding for final verification.
* Copyright 2007 Avago Technologies Limited. All Rights Reserved
*                 Anode(pin2)
*                  |    Cathode(pin3)
*                  |    |    Common(pin5)
*                  |    |    |    Output(pin6)
*                  |    |    |    |    Vcc(pin8)
.SUBCKT HCPL3140  102  103  105  106  108
land 20  102 20n
lcth 23  103 20n
lgnd 10  105 20n
lout 3   106 20n
lvcc 2   108 20n
xled 20 23 22 23 led
rled 22 23 1meg
*This is Ith, bandwidth and amplitude limitation
gpd  10 1 22 23 1
ith 1  10  dc 4.3m
cb  1  10 0.16n
rb  1  10 1500 tc1=0.004
vlimitp  13 10 dc 1
vlimitn  14 10 dc -1
dlimitp  11 13 dmod3 1.430
dlimitn  14 11 dmod3 1.430
rlimit 12 11 1000
elimit 12 10 1 10 1
mshut 11 16 10 10 nmosmod l=10u  w=1000000u
.MODEL nmosmod nmos (vto=+0.7)
vshut 15 10 dc 5
rshut1 15 16 1000
rshut2 16 17 1000
eshut 17 10  2 10 -1
*This is output stage and gate drive
vinside 28 10 dc 30
ql1  3  6  10 npnmodL
ql2  28  7  6  npnmodL
dl1  10  3  dmod3 1.430
dl2  10  6  dmod3 1.430
dl3  6   7  dmod3 1.430
qh1  2  4  3 npnmodH
qh2  2  5  4 npnmodH
dh1  3  2 dmod3 1.430
dh2  3  4 dmod3 1.430
dh3  4  5 dmod3 1.430
gidh   3   5  11 10  0.0005
gidl  10   7  10 11  0.0005
*This is iccl 1.2mA current source cricuit
q3 51 50 2 pnpmod
q4 50 50 2 pnpmod
q2 50 52 53 npnmod
q1 52 53 58 npnmod
rst2 51 52 1000
riccl 53 58 1240 tc1=-0.003
qcl 58 59 60 npnmod
gcl 60 59 10 11 0.0001
qdl 60 61 10 npnmod
gdl 10 61 2 10 0.000003
d50 60 59 dmod3 1.430
d51 10 61 dmod3 1.430
rl 58 10 1000000
.MODEL pnpmod  pnp (bf=100)
.MODEL npnmod  npn (bf=100)
*This is icch 0.7mA current source cricuit
q13 151 150 2 pnpmod
q14 150 150 2 pnpmod
q12 150 152 153 npnmod
q11 152 153 158 npnmod
rst12 151 152 1000
ricch 153 158 2000 tc1=-0.0032
qch 158 159 160 npnmod
gch 160 159 11 10 0.0001
qdh 160 161 10 npnmod
gdh 10 161 2 10 0.000002
d150 160 159 dmod3 1.430
d151 10 161 dmod3 1.430
rh 158 10 1000000
.MODEL DMOD3 D IS=2.22P CJO=1P VJ=.376 M=.139 N=1.07
.MODEL NPNMODH
+ NPN
+ IS=1.27E-17 BF=550.35 NF=1.00 ISE=4.61E-17 NE=1.320
+ IKF=7.06E-3 BR=0.11
+ NR=1.00 IKR=10.4E-3 VAR=17.47 VAF=18 RE=4.26 RC=4.12 RB=6.85
+ RBM=68.65
+ CJC=84E-15 CJE=38E-15 CJS=520E-15 MJE=0.50 VJE=0.69 MJC=0.40 VJC=0.60
+ MJS=0.344 VJS=0.60 TF=305P XTF=0.43   ITF=12M
+ IRB=95U PTF=17  XTB=0.202 XTI=3.058 TR=85E-9 EG=1.167
.MODEL NPNMODL
+ NPN
 + IS=1.27E-17 BF=600.35 NF=1.00 ISE=4.61E-17 NE=1.320
+ NR=1.00 IKR=10.4E-3 VAR=17.47 VAF=32 RE=.136 RC=2.5 RB=6.85
+ RBM=68.65
.ENDS HCPL3140
.SUBCKT LED  1 2 7 4
RSERIES 1 5 2
DELECT 5 2 LEDNOR
ELED 6 4 5 2 1
DOPTIC 6 8 LEDNORC
VSENSE 8 4 DC 0
FPHOTO 4 3 VSENSE 1
RL 3 4 1 tc1=-0.00015
EOUT 7 4 3 4 1
.MODEL LEDNOR D IS=5E-16 N=2 XTI=3 EG=2.1 BV=5 IBV=10u
+  CJO=60p VJ=.75 M=.3333 FC=.5 TT=20n
.MODEL LEDNORC D IS=5E-16 N=2 XTI=3 EG=2.1 BV=5 IBV=10u
+  VJ=.75 M=.3333 FC=.5
.ENDS LED
Here is the path I followed to create the component and fail
What am I doing wrong ? Or what I should do ?
Thanks for help.
The numbering that you have used in the SPICE model may not be matched by the pin numbering of the device in the schematic library, which if it is the same as the footprint, it will assign internal nodes of the model instead of the ones at the pad. In other words, exchange the 102/103/105/106/108 nets with the 2/3/5/6/8 nets, accordingly.
Thanks for quick response. I thought about that but instead changing nodes in spice model, I've changed Pin numberings in model 2-3-5... to 102/103..etc. The reason is spice model already using node numbers 2-3-5... Is there any tutorial or manuel for spice models for Protues ? There are lots of videos about creating non-sim models.
Thanks in advance and sorry for my poor englisg.
