gauravkothari23
Advanced Member level 2
Hi all,
I am trying to make a double sided PCB's using Dupont Photoresist dry film. my PCB manufacturing process is:
1) Drill the holes.
2) Make holes conductive.
3) Copper Electrolyte Plating.
4) Exposing photoresist film into UV Exposure.
5) Etching.
My problem is, when i expose the PCB to UV Exposure, the film over the holes does not gets harden creating a bridge over the holes, even if the holes are exposed to UV, the film over the holes peels out when the PCB is dipped into the developer solution after expose. due to which, while etching the copper inside the holes also gets etched out.
I am using 30 pieces of 0.50 watts of UV led for exposure. and exposing it for maximum 1 minute. Is it something wrong with my UV led's, do i need more watts UV led.
1) Drill the holes.
5) Etching.
