A standard CAN device will not accept your message.
As ahsan_i_h said, a standard CAN device will not recognize it and read it. I don't think you can even put a frame on the CAN without a CRC field using standard CAN controller chips. But if you do manage to put such a frame onto the CAN bus, it should not cause any trouble to other traffic on the bus. It will just be ignored by every receiver on the bus.Dear ahsan_i_h Sir I know that CAN frame will not working properly, but tell me the effect if CRC frame is not available ?
