saochandan
Junior Member level 1
Hi all,
I am using Fujitsu MB9BF506R (cortex M3 core) microcrontroller on Fujitsu FSSDC-9B596-EK-E evaluation kit for the first time.
I am facing problem regarding:
CPU clock setting
setting timers to run at 0.50msec so that the codes written inside timer ISR can be executed at the same rate
which timer I should choose for this purpose
Please explain everything from scratch
Thank you
CPU clock setting
Thank you
