Coupling signals onto DC power lines
jhendrix
Newbie level 2
Newbie level 2
I have a system with a master and multiple slaves. I currently have separate power and communication wires. (I'm using cat 5 cables). I would like to only have 2 wires and run the communications on the power wires using FSK.
I'm thinking of pulling the signal off with a capacitor and then feeding it into an opamp.
What I'm having trouble is getting the signal on to the power lines. I've thought about using a transformer (like what's in a modem) to inductively couple the signal onto the power, but I'm having trouble designing a circuit to do this.
Any help would greatly be appreciated.
Thanks
Jeff
I hope, i have understand properly.
Check in the figure i drawn for you. Connect your amplifier/transmiter to the side of C and DC wire in the end "C1".
The value of C and C1 will depend on the frequency of FSK signal . also , core of transformer will depend on the frequency , too[/img]
