couple - what is it and what can it do?
myem
Full Member level 2
Full Member level 2
couple
what is couple ???
what can couple do ???????
Re: couple
Do you mean "coupler"?
Re: couple
Yes, could you explain what coupler can do ?????
I really want to know.....
thanks
Re: couple
It can be use in measuring or monitoring in system
it can also be used for power divider
Re: couple
it can used in the detect of power ,the divide of signal,the detect of vswr and so on
Re: couple
Couple is one concept in Microwave.It has very applications.
You can see this file about coupler.
Re: couple
you also can get what you want from minicircuits.good luck
Re: couple
You sometimes used a thermometer to measure the temperature. The thermometer takes small temperature to give you the measurement. Now the thermal energy dissipated in the thermometer should be very small part of the thermal energy of the whole system. In microwave it is very difficult to divide the input power to make a measurement or to use it for some other purpose because of the reflection of power. Normally power dividers or coupler are used for that purpose to avoid the reflection of power.
:!: :idea: :?:
thanks
couple
thx
No thanks ! Read rules ! Warning #1.
/pisoiu
