Navankur Verma
Newbie level 3
We are doing a project on counting the number of people crossing through a doorway,in which we have used an IR LED n PHOTODIODE which makes a change in current from photodiode when a person crosses, and this current is supplied to two inverting amplifiers using OP AMP IC 741 which produces nearly +5V when no obstruction is caused and nearly 200 mV when it is.
These pulses are given to the clock of counter IC 4033 which shoul have incremented the count every time a person passes BUT IT IS NOT DOING SO and the decoded outputs for 7 segement display of the IC are giving the correct results.
Can any body suggest about solving this problem?
And we think that we are doing some mistake in using 4033 IC but not able to rectify it?
So need your help we have to submt this one before 20th november!!
Thanks
Posted via Topify on Android
Thanks
