[SOLVED] counter using external interrupt
cyanpraveen
Junior Member level 3
i need to count number of time the LED gets turned off... for that i had used external interrupt... but the problem is when i call the interrupt the count increases by 2 when led turned on and it increase again 2 when turned off.
In debugger mode my program works prefectly.. but while displaying only this problem arises...
Could any body pls give me a solution
The external interrupt comes from a keystroke? If yes, your problem is a key bouncing, I think so.
One solution is using a sw debouncing
Send also your program and circuit here ...
