Antrop
Newbie level 5
The project that was given to me is: Build a digital circuit that shows the numbers from 1 to 15 (and number 0 too ofcourse) on 4 LED diodes. With a switch change the numbers.
Basically the truth table 8421.
I was thinking of using a 74LS193 counter and with pressing a switch the numbers were to change. How do I go about implementing the push button so that by pressing it I change the number and that is shown on 4 LED diodes?
I saw people using 555 timer clocks for changing the counter number output but I haven't seen them using a switch. I'm also having a trouble figuring out whether I should use 555 timer too and how would I go about implementing the push button for switching the numbers.
Nowhere did it say I have to use a counter I'm aware of that but I figured that the counter was the easiest way to go (It might not be easiest way to go but that's what I think right at this moment).
