counter program of 7 segment display
suga
Member level 2
Member level 2
chennai
this is my program.In this program when I pressed the switch 7 segment starts to count 0 to 9.after that again I press switch only it will count.i need when i pressed the switch it will count continuously.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
/////////////////////////counter display  7 segment//////
#include <reg51.H>
#define p0 P0
#define p2 P2
sbit r1=P3^2;
void seg();
void wait (int j)  {
 long int  d;
  for(d =0;d<j;d++);
void main()
if(r1==1)
  seg();
void seg()
for(p0=0xf0; p0<=0xf9; p0++)
 wait(10000);
Elaborate your question Plz.
Reactions: suga
    suga
In my program r1 is a switch.once a press a switch 7 segment had count 1 t0 9.after that 7 segment stopped i want when i press the switch 7 segment has to run continunosly without stop.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
#include <reg51.H>
#define p0 P0
#define p2 P2
sbit r1=P3^2;
void seg();
void wait (int j)  {
 long int  d;
  for(d =0;d<j;d++);
void main()
if(r1==1)
while(1)
{                  //run infinitly
seg();
void seg()
 wait(10000);
Try this code, it will work
your telling about OP.OP means
Original Poster, the person who started this thread (you :-D)
Stoping is not your headache, it is according to the requirement of user. By the way it is not so difficult to stop it.
