Is cortex A5/A7 processor supports FPGA device, i know Cortex M series developed for FPGA implement ion.
if Cortex A5/A7 supports FPGA means ,what is the maximum achievable frequency?
FPGA INFO :
version :Virtrex 7 ;
device ID : XC7V2000T
Is Cortex A7 support the above FPGA family?
FPGA INFO :
What do you mean by "support"? Do you mean can I take a soft core of an A7 and implement it in a Virtex 7? Don't expect anything close to the typical ASIC clock frequencies. If you mean is there a hard core A7 version of a Virtex 7 part...then no there are no Arm support in a Virtex 7.
You really need to improve your questions they are always vague and open ended.
yes am expecting below answers,
Can I take a soft core of an A7 and implement it in a Virtex 7? and Maximum achievable clock frequency in XC7V2000T part? Is cortexA7 soft core processor optimized for Virtex 7 device architecture, otherwise which is specific for ASIC architecture.
Am going to buy a cortexA7 processor, but which should support both ASIC& FPGA architecture. So, while buying the processor we need raise any quires regards this dependency?
There is no V7 device available with hard cored CortexA7 processor?
-- Yes, anything that is VHDL/VERILOG/SYS.VERILOG can go inside FPGA, provided you use proper synthesis tools. But there are things like POR, DELAY CELLS, ANALOG IPs in the SoC will not go into FPGA. However, for ARM only design, you will not find these.Can I take a soft core of an A7 and implement it in a Virtex 7?
-- As I said, it will be well below 100MHz and No, A7 is not optimized for FPGA architecture. It is Cortex M1 which is optimized for FPGA. Not that other cores will not be compatible, but you will get very least amount of operating frequency even for a high end FPGA like Virtex-7Maximum achievable clock frequency in XC7V2000T part?. Is cortexA7 soft core processor optimized for Virtex 7 device architecture, otherwise which is specific for ASIC architecture.
From the ARM processors, I think only the Cortex M1 is designed to be implemented as an FPGA soft-core.ONLY THE M SERIES IS DESIGNED FOR IMPLEMENTATION IN AN FPGA!
I don't know of any commercially available Cortex M3 , M4 or M7 devices intended for soft FPGA implementation.
We use same processor type in ASIC design. We are checking are design with the help of FPGA.
Arrghhh!! You could have pointed out 14 posts ago that you are doing ASIC emulation.
Time to update the ignore list.
