Corrupt schematic file in Orcad?
farhada
Advanced Member level 2
Nice, France
orcad ole
I wonder if anyone here had the same problem before.
I have 2 version of OrCad, version 10 at work and version 9.1 at home. One of my designs was created in 9.1 and I worked on it on both 9.1 and 10 depending on where I was working on it.
The problem I have is that for some strange reason the desing got corrupted and I can not open it again. I keep getting "illegal OLE call" from it.
The problem started after I upgraded my computer to SP2 of Win XP (Big mistake by the way).
Any clue on how to solve this problem is highly appreciated,
Best regards,
/Farhad
Try opening the backup
with an extension *.bak.
binu g
    farhada
Also Check the file system, there may be a chance that the file security option got corupted. you can rectify it by taking the ownership of the file in administrator mode. i faced the same problem once.
Regads
Binu G
Thanks,
I checked out the backup file (it is .Wbk) but it has the same problem. It seems that the problem is permanent, I have to get back my backup from 2 weeks ago to see if it helps or is it a problem with the stupid SP2 of WinXP.
BR,
/Farhad
if it is schematic file,
check for the *.DBK file in the same folder.
open it in the capture.
regards
binu g
Thanks for correcting me. It is the DBK file and not WBK. But the problem still exists.
Tried to access the file on Win98, but it didn't help either.
I have to re-do the schematic again.
Thank you all.
BR,
/Farhad
