[SOLVED] correct fuse settings for 18F4550 as an USB device
varunme
Advanced Member level 3
I am having trouble in using 18F4550 as USB device ( I tried all the firmwares from microchip ) , I think its because of the faulty fuse settings in the burner (Microburn) , someone kindly review the setting and advice me a good setting
thanks
varun
Somehow, your picture cannot be enlarge
---------- Post added at 11:25 ---------- Previous post was at 11:25 ----------
Anyway, these are the settings using hitechC:
// PIC18F4550/PIC18F2550 fuse configuration:
// Config word 1 (Oscillator configuration)
// 20Mhz crystal input scaled to 48Mhz and configured for USB operation
__CONFIG(1, USBPLL & IESODIS & FCMDIS & HSPLL & CPUDIV1 & PLLDIV5);
// Config word 2
__CONFIG(2, VREGEN & PWRTDIS & BOREN & BORV20 & WDTDIS & WDTPS32K);
// Config word 3
__CONFIG(3, PBDIGITAL & LPT1DIS & MCLREN);
// Config word 4
__CONFIG(4, XINSTDIS & STVREN & LVPDIS & ICPORTDIS & DEBUGDIS);
// Config word 5, 6 and 7 (protection configuration)
__CONFIG(5, UNPROTECT);
__CONFIG(6, UNPROTECT);
__CONFIG(7, UNPROTECT);
Reactions: varunme
    varunme
Hi , john blue these are setting for 18F4550 for using as USB ?
Now the picture can be enlarged
its 20MHz crystal
Here are the fuses available in microburn for 18F4550 , can someone suggest the approriate fuses for 18F4550 as usb device ?
USBPLL			/by2
				No divide
Oscillator			HS OSC w/pll HS used by USB
				HS OSC  HS used by USB
				Intrn OSC  HS used by USB
				Intrn OSC  XT used by USB
Brown Out Voltage	2V
				2.7V
				4.2V
				4.5V
Powerup timer            En
                                Dis
WDT postscale		1:32768
				1:16384
				1:8192
				1:4096
				1:2048
				1:1024
				1:512
				1:256
				1:1
LPT1 OSC			Low Power  mode
				High Power mode
CCP2MX 			MUC RC1
				MUC RE7/RB3
XINST			Dis
				En
Stalk Overflow		En
				Dis
Rom Protect		0200-1FFFF Dis
				0200-1FFFF EN
Rom Protect		4000-5FFFF Dis
				4000-5FFFF EN
EEprom prot		En
				Dis
Rom table write prot	En
				Dis
EEprom table write protEn
				Dis
Boot table read Prot	0000-1FFF Dis
				0000-1FFF En
CPUDIV			Div/6 wPLL Div/4
				Div/4 wPLL Div/3
				Div/3 wPLL Div/2
				Div/2 wPLL No div
OSCSEN			En
				Dis
VREGEN			En
				Dis
Brownout Detect		En
				Dis
WDT				En
				Dis
MCLR				En
				Dis
PBADEN			AD 4:0 Reset=analog
				AD 4:0 Reset=digital
ECCMUX			ENH CCP1 RE6 3
				ENH CCP1 RH7 4
Low voltage program	Dis
				En
Boot rom detect 		0000-01FFF Dis
				0000-01FFF EN
rom protect 		2000-3FFFF Dis
				2000-3FFFF EN
rom protect 		6000-7FFFF Dis
				6000-7FFFF EN
Boot table write prot	0000-3FFFF Dis
				0000-3FFFF En
Rom table write prot	2000-3FFFF Dis
				2000-3FFFF EN
Rom table write prot	6000-1FFFF Dis
				6000-1FFFF EN
config table write prot	Dis
				En
Rom Table read prot	2000-3FFF Dis
				2000-3FFF En
Your PPLDIV is wrong. The one you are using is 40MHz crystal.
The fuses i used is marked in star
Fuse				Available option
USBPLL			/by2*
				No divide
Oscillator			HS OSC w/pll HS used by USB*
Brown Out Voltage	2V*
				2.7V
				4.2V
				4.5V
Powerup timer          En*
                               Dis
WDT postscale		1:32768	*
				1:16384
				1:8192
				1:4096
				1:2048
				1:1024
				1:512
				1:256
				1:1
LPT1 OSC			Low Power  mode*
				High Power mode
CCP2MX 			MUC RC1*
				MUC RE7/RB3
XINST			Dis*
				En
Stalk Overflow		En*
				Dis
				0200-1FFFF EN*
Rom Protect		4000-5FFFF Dis*
				4000-5FFFF EN
EEprom prot		En
				Dis*
				Dis*
EEprom table write prot    En
				      Dis*
Boot table read Prot	0000-1FFF Dis*
				0000-1FFF En
CPUDIV			Div/6 wPLL Div/4*
				Div/4 wPLL Div/3
				Div/3 wPLL Div/2
				Div/2 wPLL No div
OSCSEN			En
				Dis*
VREGEN			En
				Dis*
Brownout Detect		En
				Dis*
WDT				En
				Dis*
MCLR			En*
				Dis
PBADEN			AD 4:0 Reset=analog*
ECCMUX			ENH CCP1 RE6 3*
				ENH CCP1 RH7 4
Low voltage program	Dis*
				En
Boot rom detect 		0000-01FFF Dis*
				0000-01FFF EN
rom protect 		2000-3FFFF Dis*
				2000-3FFFF EN
rom protect 		6000-7FFFF Dis*
				6000-7FFFF EN
Boot table write prot	0000-3FFFF Dis*
				0000-3FFFF En
Rom table write prot	2000-3FFFF Dis*
				2000-3FFFF EN
Rom table write prot	6000-1FFFF Dis*
				6000-1FFFF EN
config table write prot	Dis*
				En
Rom Table read prot	2000-3FFF Dis*
				2000-3FFF En
USBPLL			/by2*
				No divide
				2.7V
				4.2V
				4.5V
Powerup timer          En*
                               Dis
				1:16384
				1:8192
				1:4096
				1:2048
				1:1024
				1:512
				1:256
				1:1
				High Power mode
CCP2MX 			MUC RC1*
				MUC RE7/RB3
XINST			Dis*
				En
Stalk Overflow		En*
				Dis
				0200-1FFFF EN*
				4000-5FFFF EN
EEprom prot		En
				Dis*
				Dis*
				      Dis*
				0000-1FFF En
				Div/4 wPLL Div/3
				Div/3 wPLL Div/2
				Div/2 wPLL No div
OSCSEN			En
				Dis*
VREGEN			En
				Dis*
Brownout Detect		En
				Dis*
WDT				En
				Dis*
MCLR			En*
				Dis
				ENH CCP1 RH7 4
				En
				0000-01FFF EN
				2000-3FFFF EN
				6000-7FFFF EN
				0000-3FFFF En
				2000-3FFFF EN
				6000-1FFFF EN
				En
				2000-3FFF En
Please change your PPLDIV to the one for 20MHz first. The one you are using now is for 40MHz
Reactions: varunme
    varunme
hi john blue
how should i rewrite to correct the fuse ?
---------- Post added at 06:36 ---------- Previous post was at 06:35 ----------
Div/2 wPLL No div ?
---------- Post added at 14:46 ---------- Previous post was at 14:44 ----------
PLL divide by 5
yes , that was corrected , it was a screen shot before correction , can u correct the typed version of the post ?
Have you tested after correction? :)
my real doubts are
Div/4 wPLL Div/3
Div/3 wPLL Div/2
Div/2 wPLL No div
USBPLL /by2*
No divide
---------- Post added at 07:08 ---------- Previous post was at 07:08 ----------
yes , i have checked
my real doubts are
Div/4 wPLL Div/3
Div/3 wPLL Div/2
Div/2 wPLL No div
USBPLL /by2*
No divide
CPUDIV determines the program oscillator clock. That depends on what your program based on. Oscillator HS OSC w/pll HS used by USB* is already correct. And I guess the USBPLL/2 means select from the /2 route. So it should be ok.
Reactions: varunme
    varunme
means ? , i am using USB hid firmware from microchip
Means the hid program is written to work at what oscillator speed. The USB works at 48MHz but your PIC CPU core can work at different speed with different CPUDIV settings :)
Reactions: varunme
    varunme
so my
setting is correct ?
---------- Post added at 07:42 ---------- Previous post was at 07:32 ----------
from firmware source code its
CPUDIV = OSC1_PLL_2
---------- Post added at 07:43 ---------- Previous post was at 07:42 ----------
from that its
Div/2 wPLL No div
isnt it ?
---------- Post added at 08:33 ---------- Previous post was at 07:43 ----------
The problem is , the usb enumeration is not correct
usb device unrecognized and VID and PID are 0000
