Cordic algorithm troubles
rawbus
Member level 1
Member level 1
So I'm doing some digital signal processing. I have a a current and a voltage signal that I am multiplying together and then filtering through a lowpass filter to get a signal that equals A*B*cos(phi)/2. At this point I want to find phi, so I need the inverse cosine function.
Unfortunatly I'm having troubles trying to write a cordic algorithm because I'm confused starting with a polar coordinate system. Everything I've read only shows rectanglular coordinates. This is my first time doing any sort of dsp so I would appreciate any help or advice.
Cordic can be used in two modes:
Rotational Mode
Vectoring Mode
To compute, arcsine, use CORDIC algorithm in Vectoring mode, with the following initializations:
x0 = 1/An (Process Gain)
y0 = input (for which you need compute arcsine)
z0 = 0
To get arccosine, value use the above algo and adjust accordingly based on the quadrant.
Let me know if you have any questions.
    rawbus
Ok, that helps alot. Thanks for the reply.
