Copying Pspice files - duplicate design
laguna92651
Junior Member level 1
I have a circuit design in pspice 9.1, does any know what files I need to copy to create a duplicate design that I want to modify. There doesn't seem to be a Save As command.
Re: Copying Pspice files
Hi
I guess u use student version, right? If you mean saving schematics, it should be possible as far as I remember. If you mean saving whole project then there might be limitations.
Cheers
Added after 4 minutes:
Hi
Cheers
Are you using OrCAD Capture? If Yes, you can copy
the folder <designname>-PSpiceFiles, and the files <design>.dsn and .opj files, and you should be good to go.
If you started from a text circuit file, you just need to copy the cir file and the associated lib files. And the *.net file if you created a netlist from a schematic. Basically any .LIB and .INCLUDE's that yo u may have in the cir file.
Regds
