copy data from CAN Chanel 1 and send that data in CAN chanel 2 using CAPL
GaneshM
Newbie level 2
Newbie level 2
"copy data from CAN Chanel 1 and send that data in CAN chanel 2 using CAPL". Hi all, I am at Starting level of CAPL programming.. i faced this question in my interview , could you please help in this?
Thanks in Advance
hi Ganesh,
This might be helpful
variables
message output_msg_name output_msg_obj;
int i;
on message CAN1.input_msg_name
  input_msg_name in_msg_obj;
  in_msg_obj = this;
  output_msg_obj.dlc = in_msg_obj.dlc;     // populate the dlc field for the output message
  output_msg_obj.CAN = 2;                     // Assign CAN Channel to the Output message
  for(i = 0; i< in_msg_obj.dlc ; i++)
      output_msg_obj.byte[i] = in_msg_obj.byte[i];    // Copy the Data in the input message received.
 output(output_msg_obj);
Lemme know if this helps.
Thanks .
