engineer1000
I am running a 50W ultrasonic transducer. I have a 1KV sine wave 153KHz across the transducer with a current of approx 0.05A giving me 50W.
For this particular application I need to run the transducer loose, i.e not bonded to a tank.
The effect of this is the transducer gets very hot very quickly. I have found that if the transducer is house in a a small box and hit with compress air (25PSI) I can keep it cool enough.
I want to replace the compressed air with a fan. Can I get one with the same cooling effect? I was thinking of a hair drying with the heater element removed.
