nicole_coocox
Junior Member level 3
**broken link removed**Colink Features:
Colink support is available in:
CooCox Colink is a small ARM Cortex M3 JTAG hardware debugging probe. It directly supports **broken link removed** and **broken link removed**, and integrates seamlessly into IAR Embedded Workbench and Keil RealView MDK.
CooCox Colink is open, you can Do It Yourself.
- Free and open
- Supports ARM Cortex-M3 devices
- Download speed up to 250 KB/sec *
- From 5-pin to 20-pin connector support
- Wide target voltage range: 1.2V - 3.3V, up to 5V with optional probe
- No power supply required, powered through USB
- Plug-and-Play installation using standard Windows USB drivers
- Integrates seamlessly into IAR Embedded Workbench and Keil RealView MDK
- CooCox CoIDE
- CooCox CoFlash
- Keil RealView MDK 4.03 or higher
- IAR Workbench 5.xx
