talking
Member level 2
I have trouble calculating an example from the attached document (class material).
From my calculation, the answer should be
X(jw) = AT/2 ( sinc(T(w-w0)/(2pi)) + sinc(T(w+w0)/(2pi)) ).
The notation w (omega) is used in my calculation, and the attached example gives an answer in the notation f.
Even though the above equation was translated to the notation f, the solution in the attached ex. is little bit different from mine.
Could you try to solve the attached example in the notation w, to check my answer? If mine is incorrect, please advise the reason.
Thanks.
Thanks.
