convertion formula from voltage to celsius
diyana
Newbie level 2
Newbie level 2
hi,
i have designed a adc..... i want to convert the output of ADC(digital o/p) to a Celsius value..is there any formula to convert that..... pls help to solve tis problem....
I think you are using a temperature sensor where it can senses the temperature of the room and generates an output voltage signal.
look into this link, you may get an idea how to calculate
https://embedded-lab.com/blog/?p=916
Best wishes :)
...or are you using a thermistor/voltage divider? (Or even a thermocouple now I think about it? :)
If you can describe the relationship between sensor temperature and ADC input voltage, you're 80% of the way there!
What sensor are you using?
