Converting Rotary Switch to Digitally control soft switch
pradipkhare
Newbie level 1
Newbie level 1
India
Currently I am using a Rotary switch, as shown in the image attached. The purpose of this switch is to select a source from multiple Sine wave sources.
I want to move to soft switch(s) instead of mechanical switch, in other word Micro controller based. Since this is not just a logical voltage output (like transistor output or straightforward) and hence having difficulty to design.
Requesting your help in this regard?
Thanks in advance,
Pradip
Depending on your input voltage levels you can use an analog switch like>
where you can select up to 8 inputs with 3 binary signals . Or just 4 inputs with 2 binary signals.
If your signal are out of the range for analog switches or you need high linearity, you can use small signal relays with a similar decoding scheme (2 bits) or no decoder using 4 bits.
" I want to move to soft switch(s) ", a soft switch is a fast fade!!. A software controlled switch is a hard switch controlled by software. If you want one of these try a 4066 chip. Comments, keep yout audio to less the .9VCC p-p, not infinite off/on ratio, but pretty good. Bias the audio to .5 VCC.
Frank
