Converting Hexadecimal to ASCII - Whats the logic?
purifier
Full Member level 4
Full Member level 4
Can someone tell me the logic of converting a hexadecimal format to ASCII format in Assembly please?
Hi purifier,
Thought I might have something local, but couldn't find it. You didn't say which processor you are using, and that makes a difference with assembly. However, I do have some links which will probably help:
for PIC micro:**broken link removed**
About 10-15 years ago in a Bulgarian magazine 'Computer' there was a
contest on
shortest HEX to ASCII routine for several processors.
Here is the routine for '51, in fact only 6 bytes long not counting ret.
Please
comment.
hex1d:
add A#090h
da A
addc A,#040h
da A
ret
Found at:http://forums.semiconductors.com/forums/viewtopic.php?t=687&sid=0c53db7bab463131a36e03470fb8b937
And another for the 51 is halfway down this page on Myke Predco's site - #3:
http://www.myke.com/51-snip.htm
A discussion on the conversion which may be useful:
And a discussion on this board can be found here:
I hope this is of some help to you, but if you have questions, just ask.
Regards,
Robert
    purifier
Wow...Thank you so much... I'm using the logic for an 8086 processor...Will get back to you if i have any doubts...thank you..
"Convert HEX to ASCII - ASM/8086"
Regards,
IanP
