Converting Gerber to PCB in Altium
mrpeja
Newbie
I tried to convert gerber to pcb in Altium, but at the end of process I got an error message, and no pcb is generated, as follows:
Error reading the nets from CAMtastic ! (C:\Build\AD.14.2\platform_edp\CAMTASTIC\Source Code\Dlls\CAMUtils\ExportCAMToPCB.pas, line 296) at 2BF0B4C4.
CAMTASTIC.DLL, Base Address: 2BAF0000.
Exception Occurred In
ExportToPCB
If anyone can help, I'll be gratefull
Mrpeja
As far as I know, a Gerber can't be converted back to a PCB because it is a production format and not a design format. A Gerber file contains only one of the many layers of a PCB, an no information on nets, components or electrical connectivity at all.
You can do reverse engineering on gerber files in Altium. I have done it in the past bit long winded but its easy really I'm away from PC at the moment when I get back I will look in to it and write the process can't remember off the top of me head
Yes you are correct there is no automated way
Mrpeja you need to extract the nest list first then export to PCb but will confirm
Hi, wizpic,
I did everything as is stated in Altium manual, import Gerber layers, import drill file, extract net list. But when I click on Convert to pcb, I have had an error message, like I wrote before:
(Error reading the nets from CAMtastic ! (C:\Build\AD.14.2\platform_edp\CAMTASTIC\Source Code\Dlls\CAMUtils\ExportCAMToPCB.pas, line 296) at 2BF0B4C4.
ExportToPCB)
So, I'm wondering, maybe something is wrong with my Altium?
mrpeja
It sounds like it try and uninstall it and try again
Hi, wizpic,
I'm not sure, maybe the my customer's computer where i tried to convert gerber to pcb, has cracked version of Atium? Can this be a cause of this issue?
In the field: Help-About stays: "Licensed to ru-board, Altium Platinum Partner
Altium Partner Special - This license can be used on all desing projects"
Any idea?
mrpeja
That should not be the problem at all, I have never had any issues before like that
So, I'll wait until someone, maybe, knew a cause of this issue.
Here is the issue again:
[I tried to convert gerber to pcb in Altium, but at the end of process I got an error message, and no pcb is generated, as follows:
ExportToPCB
If anyone can help, I'll be grateful]
mrpeja
That sounds like an Altium bug, unfortunately. Aside from rebooting Altium, there is no way around it.
In rare situations, it does help to perform the same action on another computer, then for unexplainable reasons it sometimes does work. But it doesn't seem to matter whether you have a cracked or registered version.
