hamoon2006
Newbie level 6
Hi i want to make a project which is converting 2-3 DC to 5-6 DC 200 -500mA . MAKES ME happy if someone helps me
Prototyp_V1.0 said:Hi.
You need an analog adder circuit. You also need an analog inverter after that to get voltage out being positive.
You can't use a regular noninverting opamp circuit unless amplification != 1.
Or using just a simple complementary transistor pair that can output 500mA.keith1200rs said:I'm baffled by you answer. I was going to say you need a DC-DC converter or boost converter!
