converting a .lib file to a .db file
DoorunderBhatwadekar
Newbie level 2
Newbie level 2
convert .lib to .db
w poliscz internetowy
We got a tool to convert the layouts to .lib format... we now need a tool to convert the .lib file to a .db file... ne poniters to such a tool.. will be appreciated...
write_lib
try "library_compiler" provided by synopsys
convert lib to db
Yes.You can use library_compiler to convert your libary from lib format to db format.
%dc_shell
dc_shell>read_lib ./path/library_file_name.lib(ex: TSM018AG_AASW.lib)
dc_shell>write_lib library_name -f db -o ./path/library_file_name.db
how to convert .lib to .db
%dc_shell
That's dc_shell, right?, but it really works.
lc_shell
Yes.
Both dc_shell (Design Compiler) and Library Compiler (lc_shell)
can do this translation.
lc_shell> read_lib ...
lc_shell> write_lib ...
synopsys convert lib to db
Use "read_lib", then "write_lib", of course you need a library compiler license.
.lib to .db conversion
Could you please tell me whck tool can convert layout to .lib ?
Thanks
synopsys lib convert db
You 'll need a library-compiler license to convert .lib to a .db with functional description. However for black-box translation with timing parameter only, the error message complaining no LC license can be ignored. The .db still works, who cares....
convert .db to .lib
You CAN NOT use those commands from DC if you
dont have a library compiler license.
