[SOLVED] Converting a byte array in a string in C#
dipk11
Junior Member level 2
Hi all,
I have a byte array byte[] dStream = new byte[6];
the contents are as follows
{0x7C 0x00 0x7A 0x10 0x00 0x00}
When I check the array values in watch window, I can see them converted into decimal and not hex.
I want to generate a String Data= "7c,00,7a,10,00,00"
How can I do this in my c#? Kindly help
Hi, I wrote the following code. but I am getting the string in decimal. How do I get each value in hex?
Code C# - [expand]
8
9
10
11
12
String cArgument = "";
for (int j = 0; j < 12; j++)
if (j == 11)
cArgument = cArgument + dStream[j];
else
cArgument = cArgument + dStream[j] + ",";
output:
"124,0,122,16,0,0,4,0,0,2,123,48"
I want it to be "7C,00,7A,10,00,00,04,00,00,02,7B,30"
Kindly tell me the changes in the present code...
Hey I did it like this.
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
//converting to hex value
string[] datastring = new string[dStream.Length];
for (int i = 0; i < dStream.Length; i++)
datastring[i] = dStream[i].ToString("X");
for (int j = 0; j < 24; j++)
if (j == 23)
cArgument = cArgument + datastring[j];
else
cArgument = cArgument + datastring[j] + ",";
But these have too many lines of codes...But works perfectly. And gives me 24bit data.
