converting 8051c to pic c compiler
lgeorge123
Full Member level 2
Full Member level 2
Hong Kong
I have a portion of 8051 c program, I wish to convert to ccs c compiler, can anyone help me? the line to be converted into ccs c compiler is
unsigned char *temp=(unsigned char*)_Value;
Added after 48 minutes:
original copying to ccs c compile output error message.
perhap you havent defined value or temp in your code as the rest of the code is straight forward C or it could even be something with the bracket aound
=(unsigned char*)_Value; , these are just guesses as i'm newish to C
There are a several possibilities:
1. Variable "temp" has already been declared in the current scope.
2. Variable "_Value" is not defined.
3. This statement appears outside of a function.
4. Since this statement declares the variable "temp," it must appear before most other executable statements. This may not be the case in your original code and the previous compiler may be more foregiving of such transgressions.
