Things that needed change in original system:
- continuously running fan
- switching the pump engine directly via a miniature switch in the handle and the same – quick firing its contacts
- sinusoidal rectifier to supply the engine
- badly soldered wires and often with too small cross-section
Compressor was the element that didn't need to be changed. Unfortunately, it works quite noisy.
There is a thermocouple in the handle. It gives about 35mV for 350 degrees Celsius.
There are some chips on the plate of the regulator:
- C8051F310 – the heart of the driver
- HT1621 – the driver of the display
- HA17358 – operational amplifier
PCB was implemented so it fits hooks in the housing and do not interfere with other components of the device. The whole housing was also dyed with car lacquer in spray, using a primer that was also in spray.
Link to original thread (useful attachments) – Przerobiona stacja rozlutownicza ZD-915
