Convert S parameter into TDR Impedance
mike_bihan
Full Member level 3
Full Member level 3
There is an equation in HFSS manual. However, there is a print error.
Could any one correct it and point out the reference source?
Z0*(1_re(S11)/(1-re(S11).
It seems not direct to me.
thanks,
You got the input impedance if you change _ by + but not the TDR impedance. The S-parameters being a frequency response, I dont think its should be correct but I cant help you any further, sorry.
David
Yep, just change the upper part of the formula, use + sign insetead of minus.
For more information look for the paper from Daniel Wu. There was a post recently about Ansoft presentations you can download from the web site.
I can't remember about the name of the post, but it was within last 2 weeks.
The paper was written for HFSS 8.5, but should not make any difference.
Hope this helps.:D
    mike_bihan
It does not address the principle of the equation.
Also, I can not see the reason to get real part of S11.
They do not match exactly between TDRZ and above equation. It does not looks right.
    mike_bihan
