Convert from open collector to line driver
Husanto
Junior Member level 1
please help me, i want the schematic for convert from open collector output to line driver output. how to do that?? i want to use it to control servo motor with line driver input CW and CCW?? any body have opinion for this problem??
Any open colector is a line driver as long the load is at the end of the line.
What kind of question is this in a "proffesional hardware" topic ?
:cry:
Do you have specifications of the CW and CCW inputs of the servo controller? You are probably looking for a single ended to differential driver. If you know the input specifications, finding out suitable IC will be easy.
Regards,
Laktronics
my problem is solved, thank you about help.....................
