[SOLVED] Convert .CSV to .S2P
k_shaik7
Newbie
Newbie level 2
I am trying to import two S parameter files for a 2 port device into AWR Microwave Office but I only have them as .csv's. I have tried following a previous thread by adding the # HZ ... but it doesnt seem to be recognised in MWO. Could someone help me with this please, its for a university project.
  • Sparams_sensor.zip
Solution
First of all you have to convert the .cvs file into a text file where all the lines before the datas have to be initiated by a "!", since they are comments.
Then add the line #HZ S MA R 50
that means: frequency in Hz, S paramenters, representation Magnitude&Angle, Impedance 50 ohms.
Then add the data lines composed by 9 columns that is frequency + 8 columns of Sxx datas
the data betwwen two columns have to be separated by space ot tab.
have a look to this: https://edadocs.software.keysight.com/display/genesys2010/Touchstone+Format
Solution
Thanks for the reply. I managed to get the .s2p files from my professor so I didn't do this but will make a note of it!
