convert +10v to -5v (100mA)
kkdelabaca
Full Member level 2
Full Member level 2
Hello,
Somebody can suggest an inverter to obtain -5v (100mA) from +10v .
Thks!
Take a look at the following for the MAX739 :
for a low power converter use the 555 timer to generate a 50 - 100 KHz square wave to drive a two diode rectifier (diodes are reversed from a regular two diode rectifier to generate a negative voltage). You should have -10 V coming out of which you can use 7905 regulator to obtain -5 V.
