Jspitzer
Newbie level 2
Conversion question 220v to 110v (Hair Clippers)
Dear Members,
Please forgive me if this is too elementary a question, but none of the electronic stores where I am now could figure out the problem so I'm hoping there are members here who can advise. Also, please forgive me if that has been posted before, I did a search for key words but did not find anything.
I purchased a pair of hair clippers in the US with these specs: 110V~60Hz 9W
I am now in Iran and trying to use the clippers but am having some trouble.
I have a "Travel Smart Dual Wattage Converter" with output : 110-120VAC and two settings: 0-25Watts & 25-1875Watts
When I plug the hair clippers in and turn it on, it starts shaking twice as fast and is twice as loud as it was in the US. It feels like it will explode.
I have tried this on other converters purchased here and have run into the same problem. I also found another set of US clippers with similar specs that were left here and they have the same problem.
An additional note, the clippers come with a screw that the manual defines as "Power Screw: Your clipper has a power screw and it has been adjusted for peak efficiency before leaving the factory. However, if voltage in your home is low, you may need to readjust."
When I rotate the screw to the lowest setting, the clipper just a makes very low noise and the blades do not move. If I turn the screw just a bit higher, it goes into freak out mode again and begins to shake violently.
Is there an explanation to this or a possible solution? I figured I would just go and buy a new hair clipper here that is 220v but I wanted to ask someone who is more knowledgeable than I am.
Thank you for your time.
Dear Members,
