Conversion rate ADC ?
pnanda65675
Member level 2
Member level 2
adc conversion rate
im confused with various of definition ?
what is conversion rate ? is that conversion rate can be the sampling rate/freq?
Or is that sampling rate is clk speed ?
how if if a SAR ADC has clk speed of 24Mhz, requires 6 clk cycle to do conversion..so in that case what will be the conversion rate ?
How abt tis Ms/s & Mb/s ? is both same or differ ? Plz do clear me out
conversion rate of adc
hello,
that's a good inference
sampling rate - it is the rate at which the ADC took analog samples and digitize it. technically it is the rate in which the sample and hold circuit takes data
conversion rate - it is the rate at which digital signals, ADC outputs, are produce on a continous mode conversion. Normarlly, it will take a lot of clock cycles to do that. so in your case the conversion rate is 24MHz / 6 is 4 MConversion per second
conversion rate adc
thanks neoaspilet11,
how abt tis Ms/s & Mb/s ? is it same or different
conversion rate adc wiki
Ms/s=Mhz Samples per Second
but im not sure about Mb/s
maximum conversion rate adc
Could nybody tell me what is Mb/s ?
define sampling rate adc
MS/S means mega (milion) sample per second.
Mb/S means mega bit per second.
Mb/S = MS/S * n
n is number of bits per sample.
for example:
if samples is 8 bits wide, n is 8
and if sampling rate is 4MS/S then Mb/S= 4*8= 32 Mb/S
Regards
what is the conversion rate of adc
thanks for the info mr.Davood Amerion, ill appreciate much if u could help on the other question that i've been posted..about ADC timing diagram
conversion rate in adc
i think Davood Amerion's definition is right.
you canit define the performance of a adc only with the convert speed,you should also consider the resolution and which type it use.
regards
