Conversion from fixed point to floating point and vise versa
alzomor
Advanced Member level 2
Germany
convert fixed point to floating point
Asslamo 3likom
How to convert from fixed point Q15 to floating point and vise versa in C
Salam
Hossam Alzomor
www(.)i-g(.)org
If you are using Microchip Mplab C30 compiler, if you look in the header file, 'dsp.h' you will find the following functon prototypes:
extern fractional Float2Fract (         /* Converts float into fractional */
   float aVal                           /* float value in range [-1, 1) */
extern float Fract2Float (        /* Converts fractional into float */
   fractional aVal                /* fract value in range {-1, 1-2^-15} */
You will find the functions in the dsp\src directory.
Thanks btbass
But My question is How it can be implemented in C.
I am not using Mplab C30 compiler
Salam
Hossam Alzomor
www(.)i-g(.)org
q15 conversion
Here are the functions in C from the Microchip lib.
    alzomor
fixed to float conversion
Hi
A Good and simple way to:
Convert from Fixed point to Flaoting point.
Just divide by the full scale of integer represented in the no of bits representing fixed point and type cast the result to float
example
a: fixed point represented in Q15 formate
b:floating point representation of a
b= (float) (a/(2^15-1))
Conversion from float to fixed:
a=(int) (b*(scale))
scale depends on the max value of floating point values being converted and fixed point formate result.
Salam
Hossam Alzomor
