Magdy_said
Newbie level 6
My goal is it to control one mosfet with pwm from ATMEGA32A.
after watching some tutorial and codes on internet i got this code
but i don't know how to control frequency or duty cycle, i know that OCR1A should control duty cycle but however, i change it between 0 and 255 nothing happens it only gives 50% duty cycle
the frequency changes already wwhen i change the prescaller, but i can't just take any arbitrary frequancy i need to define an exact frequency or at least an in-range frequency(i know that depends on the type of the chip), the datasheet give an equation for the frequancy of the fast pwm mode (which i am using ) but i don't know what's TOP value !! but data sheet says :
which i don't understand !
anothe thing is that i am usning "protus 8" software to test my codes before downloading it onto the avr, i just use very primite way of calaculating the output frequency by counting the squares on the osilloscope screen, protus keeps shifting the signal downwards so the pwm looks lika an ac signal, i don't know if there is something wrong with the code or protus just not very accurate!
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 #ifndef F_CPU // if F_CPU was not defined in Project -> Properties #define F_CPU 1000000UL // define it now as 1 MHz unsigned long #endif #include <avr/io.h> // this is always included in AVR programs #include <avr/interrupt.h> /////////////////////////////////////////////////////////////////////////////////////////////////// int main(void) { DDRC |= (1 << PC5) | (1 << PC4); // set PC5 (pin 28) and PC4 (pin 27) for output /* TCCR1A - Timer/Counter 0 Control Register A bit 7 6 5 4 3 2 1 0 name COM1A1 COM1A0 COM1B1 COM1B0 FOC1A FOC1B WGM11 WGM10 set to 0 0 0 0 0 0 0 1 COM1A1 = 0 normal port operation, OC1A disconnected COM1A0 = 0 com1B1 = 0 normal port operation, OC1B disconnected com1B0 = 0 bit 3 = 0 bit 2 = 0 WGM11 = 1 CTC (Clear Timer on Compare match) mode, see TCCR0B also WGM10 = 0 TCNT0 will count up to value in OCR1A, then signal timer 0 compare interrupt */ TCCR1A = 0b00000001; /* TCCR1B - Timer/Counter 0 Control Register B bit 7 6 5 4 3 2 1 0 name ICNC1 ICES1 - WGM13 WGM12 CS12 CS11 CS10 set to 0 0 0 0 1 1 0 1 ICNC1 = 0 FOC0B = 0 bit 5 = 0 WGM13 = 0 WGM02 = 0 CTC (Clear Timer on Compare match) mode, see TCCR0A also CS02 = 0 CS01 = 1 clock / 64, should not use less than this to allow ISR enough clock cycles CS00 = 1 */ TCCR1B = 0b00001010; /* TIMSK - Timer/Counter 0 Interrupt Mask Register bit 7 6 5 4 3 2 1 0 name - - TICIE1 OCIE1A OCIE1B TOIE1 - - set to 0 0 0 1 0 0 0 0 bit 7 = 0 don't use Force Output Compare A bit 6 = 0 bit 5 = 0 bit 4 = 0 bit 3 = 0 OCIE1B = 0 don't enable Timer/Counter 0 Output Compare Match B Interrupt OCIE1A = 1 enable Timer/Counter 0 Output Compare Match A Interrupt Enable TOIE1 = 0 don't enable Timer/Counter 0 Overflow Interrupt */ TIMSK = 0b00010000; PORTC |= (1 << PC4); // turn on PC4 (pin 27) full bright OCR1A = 0b00000001; // set compare register to low value to produce fast PWM sei(); // enable interrupts while (1) { } return(0); // should never get here, this is to prevent a compiler warning } /////////////////////////////////////////////////////////////////////////////////////////////////// ISR(TIMER1_COMPA_vect) { PORTC ^= (1 << PC5); }
The counter reaches the TOP when it becomes equal to the highest value in the count
sequence. The TOP value can be assigned to be one of the fixed values: 0x00FF, 0x01FF, or
0x03FF, or to the value stored in the OCRnA or ICRn Register. The assignment is dependent
of the mode of operation.
