hsj17
Newbie
I have given the following C-Code to test a 60V DC motor with [gear box ratio 16:1 and incremental encoder to see if the code calculates the speed by reading the Pulse signal as feedback for µcontroller from encoder. The µcontroller is ATmega88A-UA. The encoder RE56-3-1000-TI signals 1000 ppr. The DC motor on special occasions needs to be run at 3-4 RPM for specific task. At lower speed such as less than 5V where motor has starting voltage of 1.8V, the software seems to calculating the incorrect speed values. When at low speeds the mode is TCCR1B == 0x02, the speed value is relatively higher ranging from 255 - 1071 at 2V-5V and frequency 751Hz -3.6kHz accordingly.
When the mode is switched to TCCR1B == 0x01, the speed values calculated/observed (by debugging) ranges from 471 - 1140 at 8V - 20V and frequency from 6.2kHz - 17.4kHz.
What I have also observed that the mode TCCR1B keep switching between 0x01 & 0x02 specially at frequency between 2kHz and 4kHz.
Does any one understands what might be the trouble with incorrect value calculations. Is there some sort of timing problem? The speed variable used is an unsigned int. I need your help. There is a great possibility that things might not be well explained. I'll try my best to give right answers. The prodcut links are included in the description. Any kind of help/suggestions would be very much appreciated. Thanks
60V DC motor: **broken link removed**
gear box ratio 16:1: **broken link removed**
Encoder RE56-3-1000 TI: https://www.dunkermotoren.com/en/products/brakes-and-encoders/encoders/detail/8871005210/
"C-Code"
"C-Code"
C:
#include "iom88.h"
#include "main.h"
unsigned int Test_Speed_low; //For testing only!!
unsigned int Test_Speed_1; //For testing only!!
unsigned int Test_Speed_2; //For testing only!!
unsigned int Test_Value_Timer_2; //For testing only!!
int main(void)
// 1 rpm -> 1000 / 60 = 16,6 Pulse/s -> 1000 / 16,6 = 60,25 ms/Pulse
// 10 rpm -> 10000 / 60 = 166 Pulse/s -> 1000 / 166 = 6,025 ms/Pulse
// 120 rpm -> 120000 / 60 = 2000 Pulse/s -> 1000 / 2000 = 0,5 ms/Pulse
// 2000 rpm -> 2000000 / 60 = 33333 Pulse/s -> 1000 / 33333 = 0,03 ms/Pulse
// 8 Mhz -> 0,125 us / Takt
// Timer1 CLK/8 -> 1 us / Timer cycle -> 65535 * 1 us = 62 ms -> ~ 1 rpm
// If pulse is faster than 0.5 ms then measure 10 im pulses with
// Timer1 CLK/1 -> 0,125 us / Timer cycle -> 65535 * 0,125 us = 8192 us = 8 ms
// 120 rpm -> 120000 / 60 = 2000 Pulse/s -> 10 Pulse = 5 ms -> 5000 us / 0,125 us = 40000 Timerticks
// 2000 rpm -> 2000000 / 60 = 33333 Pulse/s -> 10 Pulse = 0,3 ms -> 300 us / 0,125 us = 2400 Timerticks
PORTB = 0x00; // No Pullups
DDRB = 0x03; // PORTB_Bit0 = 1k3, Bit1 = 0R
PORTC = 0;
DDRC = 0x1F; // Out_0-4 Outputs 47k, 22k, 11k, 5k6, 2k7
PORTD = 0x20; // Pull-Up T1 (Bit5)
DDRD = 0x00;
ACSR = 0x80; // Disable Analog Comparator
DIDR1 = 0x03; // Disable input register on AIN0/AIN1
ADCSRA = 0xC7; // Clock / 128 slower is not possible, no INT
ADMUX = 0xC5; // Int 1,1V Ref, ADC5
DIDR0 = 0x20; // Disable input register on ADC5
TCCR0A = 0x02; // T0 CRC mode
TCCR0B = 0x06; // T0 External clock source on falling edge
OCR0A = 1; // CRC int after 1 clocktick
TIMSK0 = 0x02; // Timer 0 Compare match A int
TCCR1A = 0x00; // T1 normal mode
TCCR1B = 0x02; // clk/8 source on T1
TIMSK1 = 0x01; // Timer 1 Overflow int
Value_TCCR1B = TCCR1B;
Value_Timer1 = 60000;
Min_Timer1 = 60000;
Max_Timer1 = 0;
Counter_Timer1 = 0;
Test_Speed_1 = 0; //For testing only!!
Test_Speed_2 = 0; //For testing only!!
Test_Speed_low = 0; //For testing only!!
EAL = 1;
while(1)
if (TCCR1B == 0x02) {
if (Value_Timer1 <= 500) { // < 0,5 ms / Pulse
OCR0A = 8; // CRC int after 8 clocktick
TCNT0 = 0; // Reset timer 0 value
TCCR1B = 0; // stop T1
TCNT1 = 0; // Reset timer 1 value
TCCR1B = 1; // clk/1 source on T1
} else {
if (Value_Timer1 > 40000) { // > 0,5 ms / 10 Pulse //Slow Mode
TCNT1 = 0x1FF;
TCCR1B = 2; // clk/8 source on T1
if (Counter_Timer1 > 2) {
if (Value_Timer1 < Min_Timer1) {
Min_Timer1 = Value_Timer1;
if (Value_Timer1 > Max_Timer1) {
Max_Timer1 = Value_Timer1;
if (Counter_Timer1 > 1000) {
Counter_Timer1 = 0;
Min_Timer1 = 60000;
Max_Timer1 = 0;
if (TCCR1B == 0x02)
//Speed = 60000 / (Value_Timer1 / 10); // 0,1 RPM, at 60000 uS -> 1 RPM
Test_Value_Timer_2 = (Value_Timer1/10); //For testing
Speed = (60000/Test_Value_Timer_2); // 0,1 RPM, at 60000 uS -> 1 RPM
Test_Speed_low = Speed;
else
if (Value_Timer1 > 10000)
//Speed = 48000 / (Value_Timer1 / 100); // 1 RPM, at 5000 uS -> 120 RPM
Test_Value_Timer_2 = (Value_Timer1/100); //For Testing
Speed = (48000/Test_Value_Timer_2); // 1 RPM, at 5000 uS -> 120 RPM
Test_Speed_1 = Speed; //For testing only!!
else
//Speed = 48000 / (Value_Timer1 / 10); // 1 RPM, at 5000 uS -> 120 RPM ... 120RPM????
//Speed *= 10;
Speed *= 10;
Test_Speed_2 = Speed; //For testing only!!
#pragma vector=INT0_vect
__interrupt void INT0_int(void)
#pragma vector=INT1_vect
__interrupt void INT1_int(void)
#pragma vector=TIMER0_COMPA_vect
__interrupt void TIMER0_COMPA_int(void)
TCCR1B = 0; // Timer1 Stop
Value_Timer1 = TCNT1;
TCCR1B = Value_TCCR1B;
Counter_Timer1++;
Counter_Int = 1;
#pragma vector=TIMER1_OVF_vect
__interrupt void TIMER1_OVF_int(void)
if (Timer1_OVF == 2) // Speed < 1,0 RPM
Speed = 0;
else
Timer1_OVF++;
