Noggin182
Newbie level 6
- Joined
- Mar 7, 2011
- Messages
- 12
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Nuneaton, UK
- Activity points
- 1,400
Hi All, this is my first post here so be gentle
I've got a circuit I could do with some help on. I have 5vdc (12vdc is also available) that I would like to use to control two independent AC outputs. These outputs are actually just IEC outlets and are designed to power anything. I know the easiest option would be to use a power relay but I want to use another solution, just personal preference and I want to challenge myself.
I've been looking at TRIACs. My current thinking is use the 5v output from my Arduino to control an opto isolator (something like MOC3062) connected to a TRIAC (maybe BTA16-600B). I've found several examples of this but they are all slightly different depending on the load being used.
Considering any load could be connected (if any) I'm not sure what I should do about providing snubbers, varistors or series resistors.
The main things that will be connected is audio equipment. So I guess a lot of the load would be inductive as they use transformers but there is also equipment with switch mode power supplies. I will be adding other loads later and it should also operate with no load.
Is this possible using triacs?
Any help would be appreciate, as I said I know relays might be a better option but I really enjoy learning and trying new things.
