Faizan Jawaid said:i dont understand why TIP31 transistors are used...u have`nt connect the coil terminal to the collector of TIP31...and 100 resistor will limit current...if the step motor rated voltage is same as the Vcc (5v) of transistor resistor is of no use....
Try this circuit. it can handle upto 800mA...According to the post schematic motor looks not greater than 800mA... and 74LS244 is compatible with PIC MCU...simple TTL logic buffers...
laktronics said:Hi,
Check carefully again, are n't the collectors of each pair of transistors in your original circuit shorted? In that case, your circuit should be OK.
Regards,
Laktronics
james bond007 said:hi,
your motor seems to be having a current rating near 500mA. If that's true i would suggest you use ULN-2003 as this will reduce the need of transistors in your circuit and also cuts down the cost of your project. The transistors used in your circuit is merely used as a darlington pair which provides the the isolation as well as the necessary current to the circuit. ULN takes care of that.
Sinisa said:I am sorry, but I did not pay attention to motor you are going to use, as nobody here did.
Motor you have has only 4 wires, which means you can run it only in bipolar mode. That means that driver for each wire has to be bipolar, or in other terms it has to both source and sink current depending on state required.
ULN or discrete circuits that were posted here by you and others will not work.
How should driver look like depends on your motor data. Do you have any idea of required driving voltage/current for your motors?
Actually 4th (last on the bottom) circuit on the page you just posted would work for you, one with L293 driver.
Hope this helps.
. Could you please tell why the transistor will melt? 2N2222 has continous collector current of 800mA.FvM said:Some suggestions should be treated with caution, e. g. using a 2N2222 for 500 or even 800 mA load current.
DC current gain below 100 (maybe below 50). Driving the transistor through 2k2 with 500 mA load would make
it melt down quickly.
Using a freewheeling diode to the same supply voltage for unipolar driven stepper is generally a bad idea, cause
it slows down the current decay and limits the achievable motor speed.
Secondly freewheeling diode to same voltage for uni-polar...how it slows down current decay?
How?even ULN can be used (i guess) for controlling bipolar motors with some change in programming codes. But generally bipolar motors have current rating more than 500mA which ULN cant provide
Thanks Sinisa. Could you please let me know from where do i get thorough knowledge on your concept of fast current decay (Its new for me). Any book or any reference?
