technofreaks
Member level 2
89C51 Controller Board for 4 channel Audio Selector
Control Board (micro controller board using 89C51)
Uses 89C51 as heart of circuit has connector for push buttons, LCD, ports to connect other modules, Power supply on/of .
Front Panel
Push buttons and 3 led's connected to control board(third one connected to 5vdc)
4 channel Relay Board, 4 pole relay to switch Left,Right and ground.
Common return ground is not used, additional mute relay (used during power on/off , and channel change) separate ground connection from amp for mute.
Relay board can be used with other circuits also, 5VDC relay are driven by ULN2003
Prototype likely to be ready during first week of march.
Images of PCB Artwork :
Front Panel
