Controling speed between PIC16F and DC motor
brunofunchas
Full Member level 3
Full Member level 3
Portugal
I have a project where I want to control, speed and direction, of a 100W 36V brushed DC motor. It’s a wiper motor.
I will use as inputs: STOP, RUN, REVERSE, security sensor and voltage speed reference by a potentiometer to a PIC16F or PIC18F.
My doubt is which driver IC to use for the motor? Since the ones that I have seen do not receive a speed reference, but only ON/OFF signals.
The only solution is using ULN2003 IC and PWM signal from PIC?
I would like to send the speed signal, from PIC, by I2C, SPI or 0-5V, to that IC. That IC would "deal" with the power part of the project and regulate the speed of the motor.
Thanks,
Bruno
Allegro Microsystems has a good collection of motor drivers and controllers, **broken link removed**. I think **broken link removed** might meet your needs. It won't do everything exactly how you want (i.e., the PIC, or perhaps an additional op-amp, may have to participate in controlling the speed), but it'll take care of most of the unpleasant stuff (I've burned out lots of H-bridges when I was younger).
