pradoartz
Newbie level 3
I have created a relay based circuit.
My circuit consumes 12v DC 30amps load.
Please find the image attached below in that there is a "circuit i need" box. That is the exact circuit i need. Help me to build a professional Schematic for that circuit i need.
I already got a variable resistance(1.3k to 0.1k), the relay and the buzzer.
The point 86,87 in the relay needs 12v positive and negative supply to energize it, which in turn turns the connectivity ON to the point 30,85 and the buzzer beeps.
Exactly the variable resistor i used here is a "coolant temperature sensor".
It senses the heat and reflects it in resistance. When the temperature sensor senses the heat is too high then it actually supplies 0.3k ohms and more heat and more heat the resistance becomes lesser than 0.3k ohms.
Thanks
Thanks
