control register in LPT port
e.mfr
Newbie level 5
Newbie level 5
world of electronic
lpt control register
I need information about control register in LPT port
(pin 1,14,16,17)
which is input or output?
can i use data register in input status?
thanks
inpout lpt registry
check the following
Check the "Bi-directional Ports" in the second site (beyond logic). You need to enable bidirectional mode. But normal printers do not use them as inputs.
have a nice day
SivaC
lpt + control register
join yahoo group- parallelport
from files download Parallel Port For u
read it , then u will get it
lpt control data register
control port and data port are bi-directional
lpt port registers
First, your port must be configured as a bi-directional (PS/2) in BIOS setup program. Second, you must manipulate with the direction control bit (5) of control register:
0 - outputs enabled
1 - outputs disabled
Also, you may configure your port as ECP, or as ECP+EPP ( but not EPP only!).
In this case you must set an appropriate bit mask in 5,6,7 bits of ECR register (base address + 402h for standard port, may be vary for PCI LPTs).
000-SPP (standard)
001-PS/2 (bi0directional)
011-ECP
100-EPP
    e.mfr
