Contoller a powerful generator
filjoa
Member level 4
Member level 4
Hi
I try controller speed of generator with PWM.
This generator is an 3phase generator and on max rotation it produce 320V DC(after rectifying).
I have connected on generator a resistor (10R/150W), controller by mosfet IRFP456.
This is my circuit:
where have write "Resitor" is resistor 10R 150W
where have write "Motor" is my generator 3phase
But the problem stay on mosfet heats, I have one big cooler when but when generate more power with generator and mofest burn.
Someone have other suggestion to controller this generator with PWM? I think need something more powerful than my circuit, but I don’t have more ideas.
Best regards,
Filipe Abrantes
Ordinary mosfet like IRFP need 10V at VGS
for 5V, you need use a logic level mosfet
RDS(on) is too high with IRFP and VGS=5V, so IRFP is heat
Hi
thanks for quickly reply.
but I read on datasheet and Vgs(th) is on min=2, on typ=3 and on max=4 don't is this the voltage necessary to active this mosfet?
if it stay work with 5V from my PIC, way it heat if voltage is litle? I don't understand this.
is possible you explain me more cause of my mosfet heat?
best regards,
Filipe Abrantes
hi filjoa
i see in ur drawing u use R4 1ohm res as current sense and use R9&C11 as low pass filter but not used that signal i mean voltage accros c11 its proportional to
current through R4
u drive the gate with pulse of 5v vp but current in 1ohm resister will pull up the
voltage of source for irfp460 if u have 1Amper peak pulse then u have 1volt
2 amper uhave 2 volt and like that ur irfp460 will not act as ideal switch that
will rise temperature in irfp460....... tray to reduce 1ohm resistore to 0.1ohm
Hi
I buy a driver because when I put osciloscop on the GATE I don't see square wave, and I think witch stay there my problem...
with driver I'll put on gate 12V with 150mA to try have an square wave on gate.
thanks for sugestions.
