waqas_here
Junior Member level 2
Re: Contolled +-10V required
Hey i got stuck in a problem. I need to interface a system with PLC. I got analog module for PLC which output 0-10V DC. But i need negative voltage on output. i-e when i put 3volts the converter must negate it to -3Volts. Plz suggest me IC or any circuit for that.
Thnx in anticipation
Added after 2 minutes:
One solution is to use inverting amplifier with gain 1. Any one have alternative solution plz
