FreshmanNewbie
Advanced Member level 1
![Advanced Member level 1](/styles/images/ranks/glevel1.gif)
I'm using this - Op-amp. LMC7101. V+ is 5V and V- is 0V.
I want to know whether the Op-Amp can provide continuous current output(100mA), while the input voltage is coming from DAC ranging 0V to 2V with 10mA current. we are using as a voltage feedback function along with maximum current output
In the Table LM7101A 5.0V Electrical Characteristics table, there it is mentioned as Output Short Supply Current as min of 120mA/80mA? So, its safe right? Or am I misunderstanding it? What does or when does Output Short Supply current occurs?
Also, in the same output short supply current , the values are given for Sourcing (Vout=0V) and Sinking (Vout=5V)? Shouldn't it be vice versa? Souring when Vout=5V and Sinking when Vout=0V?
