Context swithching in Interrupts
vinoth14
Junior Member level 1
Can anyone explain about context switching term in interrupts with example?
Context switching is the process of saving the current state of the process/processor when the interrupt is trigger and the interrupt service routine (ISR) is executed.
What exactly the current state involves, e.g., data, variables, etc. which maybe altered during ISR execution, typically varies from microcontroller architecture, specific compiler and issued compiler directives. The context state is often, but not always, pushed on the stack and after ISR execution restored, hence restoring the process/processor to a state before the interrupt occured and ISR was executed. The code execution flow then returns to the original process at the point when the interrupt occurred.
BigDog
