Constructing a variable power supply
spybot
Newbie level 3
Newbie level 3
I want to build a variable power supply which can provide upto 25V. There seem to be many possible options around, I dont know how to compare these in terms of efficiency
I'd like some advice on this and other possible designs
Thankyou
high efficiency = SMPS
low efficiency = linear regulator but big heat sink needed
low current = linear regulator (and simple design)
So what is the current the power supply must deliver?
Like you said, there are many possible options. To have something between an efficient design and simplicity at reasonable current outputs, I would say you could use a step down transformer and use a switching regulator. For switching regulator, check L4971, L4964, L4970, L496x, L497x. Transformer should be easy to acquire.
The easiest solution, however is, use a step down transformer and linear regulator.
The most efficient and complex solution is complete SMPS. Use a controller like UC384x, SG3525, TL494, etc. Use these to drive MOSFET(s)/IGBT(s) in either flyback, forward, half-bridge, full-bridge configuration as required (depending on power requiremnt).
Hope this helps.
Tahmid.
