constraint file VGA help
flyline19
Newbie level 5
Newbie level 5
Hello, I have a Nexys a7 100 board and I want to use the VGA port. I haven't used the VGA port before, and I haven't been able to find any literature on how to configure my constraint file. This is a LOT of text imo, so I'd just skip to my constraint file down there. I only need help with that piece (the constraint file) as I'm pretty sure the rest works fine. I provided the rest in case someone thinks that it's something else.
Here is my VGA_sync file that I followed from a text book:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity vga_sync is
Port ( --INPUTS
clk : in STD_LOGIC;
rst : in STD_LOGIC;
--OUTPUTS
hsync : out STD_LOGIC;
vsync : out STD_LOGIC;
video_on : out STD_LOGIC;
p_tick : out STD_LOGIC;
pixel_x : out STD_LOGIC_VECTOR (9 downto 0);
pixel_y : out STD_LOGIC_VECTOR (9 downto 0));
end vga_sync;
architecture Behavioral of vga_sync is
--VGA 640 - by - 480 sync parameters
--HORIZONTAL COMPONENTS
constant HD : integer := 640; --Display Area
constant HF : integer := 16; --Front Porch
constant HB : integer := 48; --Back Porch
constant HR : integer := 96; --Horizontal Retrace
--VERTICAL COMPONENTS
constant VD : integer := 480; --Display Area
constant VF : integer := 10; --Front Porch
constant VB : integer := 33; -- ack Porch
constant VR : integer := 2; --Vertical Retrace
-- Mod-2 counter
signal mod2_reg, mod2_next : STD_LOGIC;
--Sync counters
--Horizontal Counter
signal h_count_reg, h_count_next : UNSIGNED (9 downto 0);
--Vertical Counter
signal v_count_reg, v_count_next : UNSIGNED (9 downto 0);
--Output Buffer
--Horizontal
signal h_sync_reg, h_sync_next : STD_LOGIC;
--Vertical
signal v_sync_reg, v_sync_next : STD_LOGIC;
--Status Signal
signal h_end, v_end, pixel_tick : STD_LOGIC;
begin
--Clock Process
process(clk, rst)
begin
if (rst = '1') then
mod2_reg <= '0';
v_count_reg <= (others => '0');
h_count_reg <= (others => '0');
v_sync_reg <= '0';
h_sync_reg <= '0';
elsif (clk'event and clk = '1') then
mod2_reg <= mod2_next;
v_count_reg <= v_count_next;
h_count_reg <= h_count_next;
v_sync_reg <= v_sync_next;
h_sync_reg <= h_sync_next;
end if;
end process;
-- Mod - 2 circuit to generate 25 MHz enable tick
mod2_next <= not mod2_reg;
-- 25 MHz pixel tick
pixel_tick <= '1' when mod2_reg = '1' else '0';
--Status
--End of Horiz. counter
h_end <= '1' when h_count_reg = (HD + HF + HB + HR -1) else
'0';
--End of Vert. counter
v_end <= '1' when v_count_reg = (VD + VF + VB + VR -1) else
'0';
--Mod-800 Horz. sync counter
process (h_count_reg, h_end, pixel_tick)
begin
if (pixel_tick = '1') then --25 MHz tick
if h_end = '1' then --End of the horizontal scan
h_count_next <= (others => '0'); --Resetting the Horiz. scan
else
h_count_next <= h_count_reg + 1; --Increment the scan
end if;
else
h_count_next <= h_count_reg; --Not a clk cycle that is part of the 25 MHz cycle, i.e. do nothing to Horiz.
end if;
end process;
--Mod-525 Vert. sync counter
process (v_count_reg, v_end, h_end, pixel_tick)
begin
if (pixel_tick = '1') and (h_end = '1') then
if (v_end = '1') then
v_count_next <= (others => '0');
else
v_count_next <= v_count_reg + 1;
end if;
else
v_count_next <= v_count_reg;
end if;
end process;
--Horiz. and Vert. sync buffered to avoid glitch
--The sync signal will be sent when then scan is in the middle of the retrace
h_sync_next <= '1' when (h_count_reg >= (HD + HF) and h_count_reg <= (HD + HF + HR -1)) else
'0';
v_sync_next <= '1' when (v_count_reg >= (VD + VF) and v_count_reg <= (VD + VF + VR -1)) else
'0';
--Video on/off
video_on <= '1' when (h_count_reg < HD and v_count_reg < VD) else
'0';
--Output Signal
hsync <= h_sync_reg;
vsync <= v_sync_reg;
pixel_x <= STD_LOGIC_VECTOR(h_count_reg);
pixel_y <= STD_LOGIC_VECTOR(v_count_reg);
p_tick <= pixel_tick;
end Behavioral;
This ^^^ I am pretty sure works. And here (below this) is my test ckt:
library IEEE;
entity vga_test is
Port ( --INPUTS
clk : in STD_LOGIC;
rst : in STD_LOGIC;
SW : in STD_LOGIC_VECTOR (2 downto 0);
--OUTPUTS
rgb : out STD_LOGIC_VECTOR (2 downto 0));
end vga_test;
architecture Behavioral of vga_test is
signal rgb_reg : STD_LOGIC_VECTOR (2 downto 0);
signal video_on : STD_LOGIC;
begin
--Instantiate a VGA_sync
vga_sync_unit : entity work.vga_sync
port map( --INPUTS
clk => clk,
rst => rst,
--OUTPUTS
hsync => hsync,
vsync => vsync,
video_on => video_on,
p_tick => open,
pixel_x => open,
pixel_y => open);
--RGB buffer
process (clk, rst)
begin
if (rst = '1') then
rgb_reg <= (others => '0');
rgb_reg <= SW;
end if;
end process;
--Setting the output
rgb <= rgb_reg when video_on = '1' else
"000";
end Behavioral;
This ^^^ I am pretty sure works as well. And here (below this) is my constraint file ckt:
CONSTRAINT FILE BELOW
# Clock signal
set_property -dict { PACKAGE_PIN E3 IOSTANDARD LVCMOS33 } [get_ports { clk }]; #IO_L12P_T1_MRCC_35 Sch=clk100mhz
create_clock -add -name sys_clk_pin -period 10.00 -waveform {0 5} [get_ports {clk}];
#Button
set_property -dict { PACKAGE_PIN N17 IOSTANDARD LVCMOS33 } [get_ports { rst }]; #IO_L9P_T1_DQS_14 Sch=btnc
#Switches
set_property -dict { PACKAGE_PIN J15 IOSTANDARD LVCMOS33 } [get_ports { SW[0] }]; #IO_L24N_T3_RS0_15 Sch=sw[0]
set_property -dict { PACKAGE_PIN L16 IOSTANDARD LVCMOS33 } [get_ports { SW[1] }]; #IO_L3N_T0_DQS_EMCCLK_14 Sch=sw[1]
set_property -dict { PACKAGE_PIN M13 IOSTANDARD LVCMOS33 } [get_ports { SW[2] }]; #IO_L6N_T0_D08_VREF_14 Sch=sw[2]
#VGA Connector --personal note -- USE ONE OF EACH R, G, and B. NOT ALL???
#set_property -dict { PACKAGE_PIN A3 IOSTANDARD LVCMOS33 } [get_ports { rgb[2] }]; #IO_L8N_T1_AD14N_35 Sch=vga_r[0]
#set_property -dict { PACKAGE_PIN B4 IOSTANDARD LVCMOS33 } [get_ports { rgb[2] }]; #IO_L7N_T1_AD6N_35 Sch=vga_r[1]
#set_property -dict { PACKAGE_PIN C5 IOSTANDARD LVCMOS33 } [get_ports { rgb[2] }]; #IO_L1N_T0_AD4N_35 Sch=vga_r[2]
set_property -dict { PACKAGE_PIN A4 IOSTANDARD LVCMOS33 } [get_ports { rgb[2] }]; #IO_L8P_T1_AD14P_35 Sch=vga_r[3]
#set_property -dict { PACKAGE_PIN C6 IOSTANDARD LVCMOS33 } [get_ports { rgb[1] }]; #IO_L1P_T0_AD4P_35 Sch=vga_g[0]
#set_property -dict { PACKAGE_PIN A5 IOSTANDARD LVCMOS33 } [get_ports { rgb[1] }]; #IO_L3N_T0_DQS_AD5N_35 Sch=vga_g[1]
#set_property -dict { PACKAGE_PIN B6 IOSTANDARD LVCMOS33 } [get_ports { rgb[1] }]; #IO_L2N_T0_AD12N_35 Sch=vga_g[2]
set_property -dict { PACKAGE_PIN A6 IOSTANDARD LVCMOS33 } [get_ports { rgb[1] }]; #IO_L3P_T0_DQS_AD5P_35 Sch=vga_g[3]
#set_property -dict { PACKAGE_PIN B7 IOSTANDARD LVCMOS33 } [get_ports { rgb[0] }]; #IO_L2P_T0_AD12P_35 Sch=vga_b[0]
#set_property -dict { PACKAGE_PIN C7 IOSTANDARD LVCMOS33 } [get_ports { rgb[0] }]; #IO_L4N_T0_35 Sch=vga_b[1]
#set_property -dict { PACKAGE_PIN D7 IOSTANDARD LVCMOS33 } [get_ports { rgb[0] }]; #IO_L6N_T0_VREF_35 Sch=vga_b[2]
set_property -dict { PACKAGE_PIN D8 IOSTANDARD LVCMOS33 } [get_ports { rgb[0] }]; #IO_L4P_T0_35 Sch=vga_b[3]
set_property -dict { PACKAGE_PIN B11 IOSTANDARD LVCMOS33 } [get_ports { hsync }]; #IO_L4P_T0_15 Sch=vga_hs
set_property -dict { PACKAGE_PIN B12 IOSTANDARD LVCMOS33 } [get_ports { vsync }]; #IO_L3N_T0_DQS_AD1N_15 Sch=vga_vs
This ^^^ is what I have issues with (I think). and below is from the ref manual for the board:
--- Updated ---
Follow up... I think that it has to do with my monitor being 1280 x 1040. I'm trying to find the specs on its front proch, BP, and retrace ....
(2) Second follow up ... My sync file is for an old version board that is not optimal for my board and my monitor says that it can display anything below the 1280 x 1040 pixels but is failing... so I am trying to change it to a 1280 x 1040 display area
