Julian18
Full Member level 3
positive feedback in constant gm bias circuit
Hi, there.
I am kinda confused with the analysis of constant gm circuit . I am referring Tom Lee's book "The Design of CMOS Radio-Frequency Integrated Circuits", 1st edition and the derivation of constant gm circuit is as follows(see also the attachment):
Cutting the point at V1 and applying a test incremental voltage at the gate of M8, this voltage gets amplified at the diode connected MOS M9, and as Tom Lee says, "A self-consistent solution is possible only if that voltage equals the original gate drive." Thus:
gm9=gm8/(1+gm8xRs)
But, were the above equation to hold, the positive feedback will force the circuit to oscillate, which is not very good for a biasing circuit, furthermore, as I simulated the circuit, I found the above equation does not hold(I considered all the nonidealities as possible as I can). So if there is something wrong with this derivation or I have done something dumb?
BTW, in the 2ed Version of this book, the derivation has changed, and a more reasonable relation is given, which seems accurate for long channel devices.
Thanks.
Hi, there.
gm9=gm8/(1+gm8xRs)
Thanks.
